Aktuelle Zeit: 17.12.2025, 12:43:57
Ein neues Thema erstellen Auf das Thema antworten  [ 772 Beiträge ]  Gehe zu Seite Vorherige  1 ... 43, 44, 45, 46, 47, 48, 49 ... 52  Nächste
 Betreff des Beitrags: Re: Aviation Pics
BeitragVerfasst: 15.01.2021, 14:43:09
Schimpft er da drin eh so schön wie im echten Leben?
BeitragVerfasst: 03.02.2021, 08:25:10
A Lockheed A-12 mock-up mounted on a test stand for radar cross section (RCS) testing.
BeitragVerfasst: 11.02.2021, 11:49:42
In one photo: F/A-18, MiG-29, F-15, Su-30, F-22 and BAE Hawk
BeitragVerfasst: 19.02.2021, 13:45:02
de Havilland Hornet, geiles Layout find ich
wiki hat geschrieben:
It was powered by a pair of highly developed Rolls-Royce Merlin engines, producing 2,070 hp (1,540 kW) each, which drove de Havilland Propellers four-bladed propellers. According to aviation author P.J. Birtles, the efficiency and power of this configuration gave the Hornet "a higher performance than any other propeller driven aircraft".
Fuselage construction was identical to the earlier Mosquito: a balsa wood "pith" sandwiched between plywood sheets which were laid in diagonal panels. Aerolite formaldehyde cement was the bonding agent. The fuselage halves were built on large concrete or wood patterns and equipment was fitted in each half; they were then joined along the top and bottom centre lines using wooden reinforcing strips. The entire fuselage was then tightly wrapped in fine aviation fabric which was doped in place.
7 Tonnen mit über 4000 PS, hat sicher nett angrissen.
BeitragVerfasst: 22.02.2021, 15:44:44
Wie lang es wohl dauern tät, bis die durch wären?
BeitragVerfasst: 22.02.2021, 21:52:35
Brathendlgenerator mit Auswurffunktion wie beim Toaster :lol:
BeitragVerfasst: 05.03.2021, 12:55:47
Hornet buzzing around in Brisbane, Australia
BeitragVerfasst: 05.03.2021, 13:34:51
Online
..und danach hatte der Glaserer keinen Großauftrag??
BeitragVerfasst: 05.03.2021, 13:41:57
Buzzin the tower
Der weisshaarige Opa der ausschaut wie ein Seicherl, bringt das Cruiserl zum Speib'n...they don't call me Bozo for nothing...
Gesendet von meinem LIFETAB E1070X mit Tapatalk
BeitragVerfasst: 05.03.2021, 13:54:09
wolferl123 hat geschrieben:
sehr geil! danke!
BeitragVerfasst: 05.03.2021, 14:35:16
Tomcats!
BeitragVerfasst: 05.03.2021, 19:03:43
Irrer Typ
Falls wer anderthalb Stunden Zeit hat.
Capt Dale “Snort” Snodgrass hat geschrieben:
[...] that was a unique time because we actually got to engage bad guys, but the only problem was the rules of engaging wouldn’t let you shoot down the bad guys unless they shot at you. [...] So, to this day, I sorta regret the fact that I didn’t pull the trigger, because you know, I probably would have ended my career. I would've been a Lieutenant Commander, but I would have a kill on a MiG-25 which is ... ¯\_(ツ)_/¯ ... you know. I'd probably take it. And also all my retirement goes to my ex-wife, so what difference does it make if I'm a Lieutenant Commander or a Captain?
BeitragVerfasst: 05.03.2021, 20:08:50
:shock: :shock: :shock:
BeitragVerfasst: 05.03.2021, 20:23:40
Snort be like: "Hold my glove vanes"
BeitragVerfasst: 07.03.2021, 03:02:27
